Stock shifter hard to shift
  • Stock shifter hard to shift
    89 4 speed carbed.
    The shifter is getting harder to shift forward and back. Its not really binding, its just very stiff. No other issues. I have rolled around under the car to check it out doesn't seem to be much to the shifter.
    What would be the first thing to try and lube/grease up, etc.?
    Thanks
    89 L
    have you checked fluid level? low fluid could cause extra friction at the synchronizers. also how long since you changed the fluid?
    91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
    93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
    1981 ford F-100 400000+ miles ? , looks rough - runs good
    1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
      I have neither checked it nor replaced it. Was thinking I might do that as a next step just for piece of mind.
      I assume the tranny takes ATF type F? I'll have to check the owners manual. I have only put about 1000 miles on the car in between replacing all the brakes and suspension.
      89 L
        just use regular ATF
