I don't know if this is the same clunking you are experiencing or not,but I will relate a clunk I had.One of my Aspires started making a clunking noise when taking off.Could never find the source and it kept getting worse.One day the problem became very apparent.I took off from a stop sign went about eight feet and it let out a big clunk and would just rev up but not move. Disassembly of the trans revealed it had sheared all the teeth off the pinion gear. Problem found.:sad10: Is that the same as yours?I don't know.
Clunking noise when accelerating
Me neither.Originally posted by rickbz28 View PostI don't know if this is the same clunking you are experiencing or not,but I will relate a clunk I had.One of my Aspires started making a clunking noise when taking off.Could never find the source and it kept getting worse.One day the problem became very apparent.I took off from a stop sign went about eight feet and it let out a big clunk and would just rev up but not move. Disassembly of the trans revealed it had sheared all the teeth off the pinion gear. Problem found.:sad10: Is that the same as yours?I don't know.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
