Need specs for distributor attach bolts (2) for 1988.
  • Need specs for distributor attach bolts (2) for 1988.
    Some bozo stole the distributor from my Los Anchorage 1988.
    I found a distributor, but also need the attach bolts. Anybody have specs on them?
    88L black, dailydriver
    88LX silver a/c, dailydriver
    4 88/89 disassembled
    91L green
    91GL aqua pwrsteer
    92GL red a/c reardmg
    1952 Cessna170B floatplane
    An original 88
      Think he needs the specs, like M12x1.0 or whatever.
        That is 8mm x 1.25 x 30mm more or less..the washer is crimped on. The tip is for no reason ? From flange head to tip is 31mm a replacement will be 30mm. The wrench head is deeper than a replacement. The top is recessed as a of OEM bolts are.
          Thanks, Movin!
          I suspect the smooth tip is for speed of assembly, whether by humans or 1987-vintage robots.
          91L green
          91GL aqua pwrsteer
            Dog Point: A straight pointed section reduced in diameter slightly below the root diameter of the thread, usually extending in length about two-thirds the diameter of the thread. Recommended for ease in starting, to insure against stripping fine threaded products, and to increase efficiency along production lines.
              That's exactly what I said.
              91L green
              91GL aqua pwrsteer
                They disappear north of the 49 however , may be a collectors item by bozos who do not even own a festy!
