Axle Seals
  • Axle Seals
    I'm about to put new axle seals in the 89 4-speed transmission. I looked on Rockauto and noticed that left and right side seals are listed separate and have a different Moog part number (Left - 223543 and Right - 2007N). I went to Autozone to see if I could pick them up tonight and the gal there told me that the right and left side took the same seal (2007N). Is there a difference in the seals used for the right vs. the left side?
    I always use the 2007N in both sides without any problem.
      Both will work in either side. Originally the driver side has a little added rubber peice I'm assuming to keep out road grime from the center of the road.
        Thanks.
