Rear hatch glass removal.
  • Rear hatch glass removal.
    Any tips for removing rear hatch glass without cutting the rubber or breaking the glass?
    Thanks
    Ian
    Use oil or soap. Soap is cleaner.
    Start on the inside on a corner and push.
    Rolling the rubber inward while pushing. Once it starts to go it will all go.
    The glass is pretty tough , I've layed a hatch on the ground in the grass and stood in a corner and pushed one out that way. I wouldn't recommend that method but I didn't care about the glass although I didn't break it.
    When reinstalling I like the rope method rather than the hook tool method. Use soap on the rubber a helper out side pushing while you pull the rope from the inside helps.
      Describe this rope method please?
      91GL BP/F3A with boost
        I didn't have any rope. So, I just used some telephone wire. As you pull it out, it curls the rubber to the outside.
          Here is a write up.
          '89L 110k mi. BP/G swapped
          '90LX 68k mi. wrecked 12/14 RIP
          '90 F250 4X4 108K mi.
          '13 Kia Rio 5 LX 70k mi.
          '18 Kia Soul 40k mi. Daily
          '64 Studebaker Gran Turismo Hawk
          '66 International Harvester pickup
            A pretty good video demonstration;
            Matt and Scott Goodwin, from Goodwin Restorations, remove and replace the rear window gasket on this '67 Chevy pick-up using the rope-in method. Most vehicle...
