I need help getting my rear drums off, the brakes arent locked up, so i can spin the drum freely, i took the spindle nut off and it must be stuck on the spindle, also does anyone have any tips for changing out the wheel bearing or rear brakes in general?
Rear drum stuck on
Give it a small whack with a hammer to see if it frees it up. If not, try a medium whack.I like to put duct tape on the metal hammer to prevent hurting the thing I'm whacking.Last edited by TominMO; 06-17-2015, 05:55 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Only problem with those is the backing plate is in the way and wouldnt let me put say a 3 or 2 jaw puller on it... if i can find another backing plate i might just cut some slots to allow the puller... I'll see if i can source a hub puller though, looks like that might workLast edited by Diesel_River; 06-17-2015, 08:02 PM.
I have had this before. I jacked the rear end up, chained the drum via the lug bolts to another car, filled the hatch with concrete blocks, and pulled the car so hard it came off the jack stands. It still wouldn't come off.
If the spindle nut is off and you can also get the keyed washer off, take a cheapo bottle torch and heat up the race of the outer bearing. Then cool it quickly. Do this several times and then use a punch and a hammer to shatter it. It should then fall off.Last edited by sketchman; 06-17-2015, 08:44 PM.Any difference that makes no difference is no difference.
Uh oh... Do i need to take that out? I'll be honest i have next to no experience working on the rear brakes of a FWD carOriginally posted by sketchman View PostI have had this before. I jacked the rear end up, chained the drum via the lug bolts to another car, filled the hatch with concrete blocks, and pulled the car so hard it came off the jack stands. It still wouldn't come off.
If the nut is off the washer won't hold the rest of the assembly on, so the issue is probably that the race has welded itself to the axle stub. That's what mine did years ago.
If you can't get the washer off you could probably shatter it the same way I did the race.Any difference that makes no difference is no difference.
Put the tire back on and pound on it from behind. Make sure the car is securely supported so it won't come off it's supports when you strike the tire.
And release the parking brake.
Last edited by WmWatt; 06-18-2015, 05:45 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Sounds like you will be putting on a whole new brake anyway, from the backing plate on out, if it is all welded together. Just unbolt the old backing plate from the rear (and the hydraulic line), toss it, install new brakes/drum backing plate that you will have to get anyway.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
This worked for me and I think WmWatt suggested it to me a couple years back when I had the same problem. Put tire back on and smack it on different sides til she breaks loose.Originally posted by WmWatt View PostPut the tire back on and pound on it from behind. Make sure the car is securely supported so it won't come off it's supports when you strike the tire.
Were you having bearing issues to start with? I have had the bearing fuse a couple of times recently and you can get it all apart with some decent effort. As stated above....take the nut off and leave the tire on the drum. Use a 3lb sledge from behind the rim and it will eventually pop all off leaving the inner piece of the inner bearing on the spindle. I used a dremel with a fiber blade to cut through the piece until I got to the spindle then used a chisel to spread it apart and pop it off the spindle. I had this happen once on each side at different times and the first one took me a day and a half of trying everything to get it apart. I had no electricity available the first time, the second time took me a 1/2 hour with the dremel. Good luck no matter what the problem actually turns out to be."FLTG4LIFE" @FINALLEVEL , "PBH"
