how do you do it? i dont know much about the mechanics of these cars yet, will i have to drop the tank?
fuel pump replacement?
I knew I should have made a video of it saturday :lol:------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Re: fuel pump replacement?
The FI cars have the pump inside the fuel tank and there should be an access cover in the cargo area.Originally posted by YpsiBobhow do you do it? i dont know much about the mechanics of these cars yet, will i have to drop the tank?
On the carb'ed cars, the pump is bolted to the back of the engine. Just did this to mine Monday. Flip back the air filter housing, remove two bolts and three hoses. Took about 30 minutes total... 10 minutes to actually change the pump and 20 minutes spent looking for the D*** mounting bolt that fell and somehow became lodged in a u-joint in the steering linkage! :evil:
Amanda
just be sure to relieve the system pressure first. just pull the efi fuse and crank the engine and idle till it stops.91 u.s. festiva L 189423 mi. GL int. , engine started smoking [sold]
93 u.s. festiva gl 222000 mi. bad engine , parts car [sold]
1981 ford F-100 400000+ miles ? , looks rough - runs good
1963 1/2 Ford Falcon 4 door base model , 106000 original miles , second owners
