93 festiva , wont start
  • 93 festiva , wont start
    yesterday my car ran fine , today it suddenly wont start , battery is fine ,turns engine over easily, has gas, seems to be getting fuel thru filter, air filter clean, plugs clean, fuses fine, ..... any ideas on what to check next? sensor? coil? computer brain?
    I've had a bad coil do that. Plus if you had the VAF disconnected and forgot to reconnect it, been there done that.
      Be sure your inertia switch hasn't popped.
        Pull the distributor cap off and make sure the rotor is turning when you crank it. If not, timing belt is broke. If so, put the cap back on and make sure you have spark.
        Rick
        1993 Ford Festiva
        2000 Ford E350
