I am having trouble finding a used mass air sensor?(If that is what it is called) for a 91Festiva GL 3spd. It is the sensor that sits above the air filter. Will other sensors from compatible cars work. I can find Aspires, mazda 323's and escorts but would the engine size have to be 1.3(B3) for the sensor to work correctly. Thanks for the help.
mass air sensor compatability
VAF meter .
I would make a post in the F/S wanted section.------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
bbqsauce,
Others will work!
But need to make mods
I have one I could be made to part with!
PM me.
You need to let us know where you're located!
Someone could be just down the road with the needed part!
Even just a state, if you don't want us unsavory Festiva drivers to know were you live!
Pu241'93 Blue 5spd 230K(down for clutch and overall maintanence)
