Where is it? Is there somewhere that has pictures? Thanks.
Locating the front crank seal
OK, there are 2 pulleys on the front of your motor. The bigger pulley on the bottom is the crankshaft pulley. if you take that off, there will be a gear on the crankshaft for the timing belt. you have to take the timing belt off to get the gear off. once u pull the gear off, you will see a rubber circle about 1'' in diameter. this is your front crank seal. I hope this helps.
