I recently took my car in to get an oil change and a service. When I got it back I was told there is a problem with the brakes (and I knew something was wrong but I didn't quite know what it was). Here's the problem: my brake pedal pretty much goes all the way to floor. but it still brakes the car. However, I had no brake fluid in the car. So he put some in but the problem still persisted. The brake pedal still went all the way to the floor. The mechanic thought there is a puncture in the brake fluid line, or there is a problem with the master cylinder (I don't know what the master cylinder is so, if one of you could tell me that would be great, ha). He didn't quite diagnose what the problem was but I was hoping you guys could help me instead of me taking the car back in. But could you fellas help me figure out the issue here? I am still learning car lingo so bear with me if I ask a lot of questions. Thanks for your help in advance.
-Mason ('89 ford festiva L)
p.s. I am doing a coolant flush this week too. Any suggestions on what type of cleaner and then radiator fluid I should use?
