I want to swap the a/c out of a 90 festiva (automatic/injected) into my 88 (5 speed/carb) has anyone here done this before? Other than the obvious components, what else needs to be swapped? I know I need the climate control switches, heater/evap case, compressor w/brackets and pully, condensor and lines. I also want to convert it to r143a. this should be a no biggie, but figured I'd ask here first. After the swap is done, I'll be parting out the 90.
Lobo
Lobo
