replaced head gasket now won't start
  • replaced head gasket now won't start
    I have a 92 festiva that I have replaced the head gasket I hooked everything back up tried to start the engine it started for about 30 seconds and died then wouldn't start back up I know I need to recheck timing belt is there anything else I should check
    Make sure the VAF meter is plugged in and all of your intake hoses are tight.
    "Fred" 93 Festiva L B6-ME Swap
    “Though he is small, he is but fierce.”
      Recheck your coil wire. Maybe it was loose?
        Thanks for the ideas of stuff to check if I get off early enough I'll get those checked tonight and I'll let you guys know my findings
          Ok I reset the timing and rechecked all the wires I finally got it to start but now it's making a strange noise and dies after 30 seconds I did an oil change and replenished the antifreeze just can't seem to figure it out
            How did you reset the timing? Why was your anti-freeze low?
              All is good got it running like a top was out of gas forgot how low it was before I started working on it
                It's always the little things......:-)
                  It probably don't help that I started drinking at 1 pm and by the time I retired for the day it was 11 pm
                    Dude! Like my fuel pump dying when I did my B6 swap, then forgot I drained the gas when I did fuel pump and spent another three hours wondering what else could be wrong? Yep!
                      lmao. It's a love hate with stuff like that. Hate because it's like wow that was stupid. Love because nothing is really wrong!
