fuel sender
  • fuel sender
    My festy fuel gauge reads empty all the time. I took out the pump/sender to see if maybe any trash was on the sender. No luck. So searching the forum I found someone mention this from fourgreen...My question is has anyone tried this?? Does look real close to what mine looks like.
    Shop wholesale automotive parts & accessories direct from manufacturer. Window visors, floor mats & more for dealerships, resellers, and body shops. Global B2B shipping since 1980.
    1990 Red Festiva STOCK "pregnant roller skate"
    1989 Yellow Festiva BP swap "Freebird"
    2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
    2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
    2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
    1994 Ford F150 5.0 Completely stock.
    I haven't tried it. I bought the last Ford Festiva sender from Green Sales. I had to remove the light blue connector and re-terminate.
    Works perfectly.
    I have a 1993 Kia Pride shop manual. I can check if the sender resistances are identical or not, when I get home from work tonight.
      Ok that would be great. Thanks
        The Pride fuel sender is calibrated for 7Ω full, 32.5Ω half full and 110Ω empty.
        The only difference is that Festivas are 95Ω empty.
        O.K to buy. Holes can be slotted to fit if necessary.
          Do you think it would work properly?
            Yes. I will buy it from you if you have any difficulty adapting it.
              Ok sounds good then. Thanks for the help.
