93 Festiva won't run
  • 93 Festiva won't run
    My 93 Festy starts, but as soon as I let the key go it stalls. I changed the fuel pump and ignition switch. Any suggestions?
    Check afm plug , and make sure your intake tube is in tact with no holes or loose connections.
    Check for loose or missing hoses on your intake.
      Did the car run fine before you installed these partsand now it doesn't or did you buy a non running car, replace those parts and it still doesn't run?
        Usually a bad electrical part of ignition switch turn the key to run position .Check for voltage at the coil I bet you don't have any if you don't then test the ignition switch for continuity in run position.
