20150901_101609.jpg where do the two vacuum lines go ? The two next to the secondary opening in the manifold on the drivers side one is a straight metal nipple one is a tee metal nipple I'm not sure if this pic is good enough.Thanks
vacuum
vacuum
30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.Tags: None
I tried using your facebook link before I posted this and I do not need luck does anyone know where these two lines go? Thank you.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
That was supposed to say photobucket not facebook.which for some reason will not open the pictures when I try on my phone.Guess I'll have to make some time to get to the library and jump on a computer.Originally posted by ricko1966 View PostI tried using your facebook link before I posted this and I do not need luck does anyone know where these two lines go? Thank you.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
Is it the physical shape of the lines that is different? Although the vacuum routing diagrams are drawn quite differently, I traced them all, line by line, and they all route to the exact same points - with the possibility that there could be differences in where the vacuum is sourced off the manifold. Maybe there is some difference in the 88 & 89 manifolds? I have an 89 4-Spd MTX, nothing looks like it could be modified.Originally posted by Movin View PostThat picture does not look like my 88 carbie, what is the engine description?When I'm good I'm very, very good and when I'm bad I'm HORRID.
Bought the car 01/1988 festiva with no carb.manifold or distributor.Bought manifold,distributor and factory reman carb off Craigslist.I assumed all carby festivas had same manifold and carb provided they were both from manual trans.A/C equipped cars.Gentleman I really appreciate your time and help with this thing,it is going to be quite a challenge getting this thing back together since I didn't take it apart.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
[That vacuum diagram, top left, is from page 103 of the 1988 EVTM. It only depicts 1 of the 2 vacuum control valves which are under the intake manifold. The rest of the vacuum diagram is on page 101 of the 1988 EVTM. The drawing, top right, is on page 30 of "Festiva- Engine Emissions & Related Systems" showing the same vacuum connections laid out in another configuration. The emissions label has the same diagram used on page 112 of the 1989 EVTM.] The vacuum diagram I used on photobucket is from the 1989 EVTM, which has the complete vacuum circuits drawn together in one drawing (like the emissions label in your post). Just glancing over the drawings, I thought there would be some differences which I wanted to know about. The 2 different years are laid out differently and appear to be different, but they are not. I have both EVTMs. I took paper copies of both years and using a marker, matched each of them line for line. At this point, I don't believe any differences will be found between 88 & 89 carbs.When I'm good I'm very, very good and when I'm bad I'm HORRID.
Attached FilesWhen I'm good I'm very, very good and when I'm bad I'm HORRID.
Thats a nice drawing, and text...I can't even make stick figures lol. My white car has like new vacuum hose as it was a toad. If you need the color or check pattern off a hose I have a pretty clean example, and they are all still there and working good.Reflex paint by Langeman...Lifted...Tow Rig
Movin, although not strictly needed, I would like to find out how many, and which, of the vacuum hoses originally had colored hash marks. I'm not sure if all the marked hoses were shown in the Festiva literature. Also, if someone can authoritively tell me it's OK to put all the pictures (13) on the forum, I'll see if I can get them to post right. I thought it might be a little too much - never thought there could be a problem to access photobucket.When I'm good I'm very, very good and when I'm bad I'm HORRID.
