Originally posted by bravekozak
AC repair
I finally found reference to documented cases of automobile occupants injured by a refrigerant flash fire. I had been searching for the wrong refrigerant. No one yet has been injured by this petro blend type of refrigerant in a car. But
R12, and 134 besides turning toxic in the presence of heat explodes when a source of ignition is present.
Quit saying "but it can't burn" lol...read it !Reflex paint by Langeman...Lifted...Tow Rig
If you can get R12, use it. out here it is typically 5% humidity on a wet day, 20% when raining....hard on A/C system efficiency, the other refrigerants fall short.
R12 exposed to a hot exhaust manifold turns to phosgene gas (carbon oxychloride), COCl2,
Poisonous, used in chemical warfare. All refrigerants carry some risk...
Movin and Bravekozak have it right.No car too fast !
I. Wasn't concerned about a crash or even a running vehicle I was more thinking of an evaporator leak on a parked car with the windows up a little static electricity or ?, chances are really slim but still not one I would take.Anyways looks like he got his refrigerant and all should be good.Originally posted by ricko1966 View PostMy biggest concern on flammable gasses in A/C would be an evaporator leak would fill the interior with flammable whatever. A/C should be evacuated any time the system is open, if it will hold vacuum for 20 minutes chances are you don't have any leaks and some refrigerant s when combined with air creates acid which can damage your system as well air in the system changes your pressures making the system less efficient.A vacuum pump can be easily made from an old refrigerator compressor30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
I had a 50' semi trailer full of banned mixes. Took a serious fine and pulled my 401k and bought every bottle I could find anywhere in the neighboring 5 states.
Yes. The fine was pennies compared to my profit. Supply and demand !
Good luck!
Sent from my One using TapatalkLast edited by eurotiva; 09-12-2015, 10:02 AM.
I don't understand..the people hurt by flash fire had R12 or 134. Nobody in a car hurt by blends. Yet lol.Originally posted by ricko1966 View PostI. Wasn't concerned about a crash or even a running vehicle I was more thinking of an evaporator leak on a parked car with the windows up a little static electricity or ?, chances are really slim but still not one I would take.Anyways looks like he got his refrigerant and all should be good.Reflex paint by Langeman...Lifted...Tow Rig
Condoms, seat belts, and approved refrigerant are all good things.I remember when no one thought the asbestos from clutches and brakes would hurt us.I was actually made fun of for worrying about asbestos in the 800's no one takes an air hose and blows all the dust the backing plates and drums anymore.Cigarette packages have warning labels etc.etc. Some alternatives r efrigerants may be fine only time will tell.But there are some that definitely would scare me.When I was studying and getting my ASE.in A/C so I could legally buy r12 and continue to service a/c.We were told stories of people charging with propane and blowing up cars, maybe it was b/s maybe it wasn't but I still will run r12 and 134. There has to be a reason 19 states have made flammable refrigerant illegal for automotive use.Maybe it is money maybe it is safety but I will keep wearing seat belts and condoms and washing brakes out not smoking and also using approved refrigerant. Big chicken huh.30 + Vehicle projects right now.7 Festiva/Mazda 10 GM IDK how many others,hope that helps explain all the stupid questions/shortcuts/interchanges etc. trying to liquidate so I concentrate on the good ones. Goal finish 1 amonth using as much stuff as I already have accumulated.
I am with you in general, I think the silica in ceramic brakes will be as bad as asbestos. We probably had the same instructor for R12 . The schooling we got in college is based more on fact. The trainers we got for our license were employees of the company selling the freon. There was a video they had showing a car blowing up from a freon leak. It turns out it was firemen training and the explosion was not refrigerant. They had tried all day to get the refrigerant to blow and it wouldn't. They finally used propane for the training for the firemen.
They were charging a car with freon . They had drilled a little hole in the cars evaporator. They plugged the evaporator drain. A candle would not blow it. The reason is the system was not operating with oil and hot. Hot vaporised oil will flash burn. The cars that were for real in an accident and had the AC punctured had nonflammable freon but the AC oil was explosive. This same condition will happen with the blend gasses sooner or later. There is just so many more 12 and 134 systems. Corporate lies with full government support because it is huge money lining the right pockets.Reflex paint by Langeman...Lifted...Tow Rig
Finally got it working! I replaced the compressor with a NOS unit from Rockauto (last one, sorry), replaced the expansion valve, cleaned out the evaporator, and replaced every O ring in the darn thing. Got some 40 year old cans of freon from an old guy on Ebay. Pulled a vacuum on it and it held for 5 days while I waited for the freon. Charged it up tonight and it is blowing cold as a witches, well, you get the idea! Long as it doesn't leak I am in business. I don't think it will. The throttle kicker on my Escort carb wors perfectly. Keeps the RPM's at about 900 while it is on. Worth while project and not horribly expensive. I think you guys are right about using the R12 instead of something else. Thanks.
