No power, lights or electric
  • No power, lights or electric
    Hey everyone I'm new here. I recently bought a 93 Ford Festiva but when I hooked up the battery nothing turns on or works at all and yes the battery is brand new. Any ideas?
    Also the car has a shortage to the fuel pump but I can't find the wiring diagrams anywhere.
    Welcome to the forum!
    First, confirm that the battery is not dead, even if it is brand new.
    Then check that the ground wire is actually connected to the car, not just the battery, and looks free of corrosion.
    Next, check the three wire fuses on the driver side front strut tower. It's actually best to replace them with normal fuses, 30-40-30. Make sure you get the long-legged fuses, as there are shorter-legged ones that look the same.
    Check the fuses in the passenger compartment; but since you say nothing works at all, it's probably farther upstream, in the stuff already mentioned.
      You really need an EVTM.
      Make sure your grounds are clean and tight.
      Buy a cheap 12V test light.
      Good luck.
        The headlights should come on with with no key in the ignition so you can rule out the ignition switch and wiring.
          Turns out it was one of the fuse links one the strut tower, I'm just missing one but now I just need to figure out the fuel pump. What wires go where?
