Needing vacuum hose routing diagram for 1989 festiva
  • Needing vacuum hose routing diagram for 1989 festiva
    Just bought 89 festiva. 1.3L fuel injected "K" vin. Was missing just about every hose! I've searched forever online and can't find any diagrams or photos. Any help would be greatly appreciated. Please and thank you!
    Here you go!
    V is for vacuum.
      Transmission control modulator
      Here are pictures of the areas of concern. Top valve on top of distributor according to what I found on the web and numerous useless repair manuals is for vacuum advance.not sure where bottom valve needs to go. The module on top of transmission is for changing of gears? One vacuum line coming out of front of transmission in last pictures that I have found is possibly a spare vacuum but doesn't seem right should hook up somewhere. In the front of transmission or vacuum line enters is a park neutral safety switch. Vacuum canister has hose cut underneath not going anywhere should hook up somewhere in system. Countless hours looking for diagrams and several manuals purchased no luck.image.jpgimage.jpgimage.jpgimage.jpg
        That service manual is of no use. Supposed to have two pages of vacuum diagrams in it but only has one page. Maybe mine was missing that page but it was not tampered with as far as I could see.
