fuel line replacement?
  • fuel line replacement?
    i replaced the pump, siphoned out the old gas, unhooked the line before the filter and put it in a jar to see what would come out and the gas that was in the jar is reddish brown with lots of rust in it, so I'm going to replace the fuel line. will i have to drop the tank to do that? my festiva is getting expensive. :x
    AIM= bobbo216
    id say just let it run into a bucket for awhile because its prolly just stuff from the tank, even tho u siphoned it out there is still sedement at the bottom, which can be picked up, just let it drain foran hour to see if it helps any
    2007 Ford Taurus 23-25MPG
    1976 Chevy Silverado (my toy)
    1951 Ford Deluxe, being rebuilt
    Have an old car truck or tractor? Go here.
    http://www.aintperfect.com/
      probably rush in the tank also in the lines too probably. i know they sell a coating you can pour into your gastank like rhino-liner or something. Might want to look into it
