Aspire SE ignition fix
  • Aspire SE ignition fix
    Might have posted in another section but am posting in the correct one now.....
    Would like to get some help with fixing the ignition on the SE.... Now is it as simple as hooking the wires back together and plugging in the ignition or would that keep the car and starter on 24/7 now that it has been tampered with? I know you can start it with a screwdriver in the mean time until i can get a new ignition with key but I don't want to have to jump wires to start it
    Sent from one of my 2 iPhones using Tapatalk
    Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
    Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
    Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
    it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
    Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
    TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
    bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
    '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
    SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
    R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
    R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
    R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
    R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
    R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
    sorry bump
      yikes those bare wires are scary!
      88 Ford Festiva LX "Miogi" B8-ME swapped.
      93 Ford Festiva L "Haywire" Rat infested trashcan WIP
        that's how you start it right now
          oh so your switch is bad? I could see if an aspire at the local lot has a switch for you
            I think the ignition is still good just gotta take it apart and see if there is still leftover bits of key in it.... I need the whole piece that you stick the key in to start the car (with the key!).... it was the last owner that messed that up
              Oh OK I broke my key off in my 93 rustiva. Somehow I managed to get it out and get a new key made. If I can find a compatable tumbler and switch I will let you know.
                needs to come with a key
                  Forgot to include that in the sentence
                    I would just tape those wires up as they are and try to use the switch to see if it starts. I do have another ignition, how does $20.00 plus shipping sound? I have no idea what they are worth really. If you call a locksmith to remove part of a broken key they use a small saw blade (usually part of a very small scroll saw blade) and push it in next to the key and turn it towards the key so the teeth bite into the key and then slowly pull it out. It sounds much easier than it is to do.
                      Ya that sounds great! I unhooked the battery as the radio is also wired to constant power.... I just need to match wires and plug the ignition back in temporarily and start it with a screwdriver and see if this will work and not blow up in my face aka sparks or melted wires
                        Pm'd you
