Hey everybody, wanted to ask your expertise if I may. Ive got an 89 Festiva. Its been somewhat of a frankenstien machine. Has a homebrew A/C delete, the wiring is rough to say the best (works, but splices everywhere) but it ran fine for the first 2 weeks I had it, and it lost compression. Prior owner did a head job on it, head gasket and up, and it was shotty work at best. I got it tore down to find the root cause of the freshly rebuilt top end losing compression. Long and short, the 2 middle pistons are burnt up, and one is damaged. Looks like it happened when they ran it hot, maybe it dropped a valve, etc... the head looks brand new, freshly cleaned up and new valves put in, but the pistons are junk. Not sure why someone would put it back together like that, except to set up a return visit to do more work
. Anyway, im at a crossroads. The motor has 150k miles on it. Fresh head, but all the hydraulic rockers are shot. Have a full set of adjustable manyal ones to swap in though, so thats not a huge issue. But wanted to get some advice, since this motor has a good new head, should I go ahead with putting pistons and rings and bearings in it and do a good rebuild, or should I invest in a different engine to swap in? $$ is the big object here, trying to decide whats better in the long run, but cheaper at the same time... I have all tools and knowledge to rebuild motor, or swap, so it goes either way.
