I really don't know why nothing I touch ever goes smooth.
00 Honda CRV 2.0
Came in for a burnt exhaust valve. I changed them all and ground them in. Changed the seals too. Most annoying seal design to get off I've ever seen, BTW.
Now it idles rough and is misfiring heavily on #3 AND on every cylinder randomly. But then you rev it and it sounds fine. Strong and smooth. Drop back to idle and it goes ape fleas again. Can't hold steady and misfires.
I've done the following, nothing of which has done anything to stop it.
1. Swap plug wires, plugs, injector wires, injectors.
2. Check comp for giggles. It is fine.
3. Changed plugs for giggles. No change.
4. Adjusted valve lash. No change.
5. Checked rotor and button. Looked brand new.
It's insane. Everything I can physically check seems fine, but something obviously isn't. Any ideas?
00 Honda CRV 2.0
