So I just got around to dropping my newly rebuilt B3 in about 2 weeks ago, and right away it had an idle problem.(It would only run over 2000 rpm) I didn't really have a lot of time to work on it recently, so fast forward to yesterday I start doing some research. I found a thread suggesting to unplug the coolant temp sensor and try starting it, and when I did it started right up and the only symptom was a fast idle. (~1250 rpm) I even drove it around the block a few times and in the driveway. Well I go out this morning to start it and all my problems are back. I went out and got a new coolant temp sensor and dropped it in, but still the same problem. The next thing I looked at was the IAC, in the Haynes book it says acceptable resistance is 7.7-9.7 ohms and mine had a resistance of 10.3 ohms. Could this be the cause of the issue? I can't seem to find a replacement anywhere but I can keep looking.
Sputters and then dies after rebuild
