I have an Aspire if that makes a difference. So late last week I had the wheel and axle off and got a new outer bearing onto the rear brake drum without pulling the drum off or changing the bearing race. I was running out of day and the drum seemed tight otherwise on the pads- I was afraid it would not go easily back on
If I go in again- or simply to understand the repair- WHERE are the rear inner bearings located? Are they on the back of the drum? or are they further in? Do the pads have to come off to get to the inner rear bearing ? And where is the race and which way does it point?
I have seen some crude schematics but not sure what they indicate.
for instance #4 here appears to be the bearing. What are parts 6 and 7- is 6 the race? does it sit up against the drum or against part #8- and face inward or outward- i.e. is the race toward the car like the outer bearing or in the drum with the bearing tapered toward the car?
What is that gnarly looking part 7?
thank you.
thank you.
