Just a reminder to everyone to grease your caliper slider bushings. The haynes manual does not talk about this so i forgot to do it and perhaps other members have as well. I thought my festiva was braking fine but i went to put my winter tires on the other week and noticed that some of those springs on the front calipers had come off on each side, one of the pins that holds the brake pads in was gone and the other was half way out. Also on the one side my inner brake pad was worn way more than the other. Long story short the calipers are held on by 2 bolts each. Those 2 bolts go through 2 bushings. Those bushings slide on the caliper to allow it to move back and forth for your brakes to work properly. I forgot to grease mine for about 5 years... :/ they were so corroded up that they werent allowing the caliper to move back and forth so only my inner pads were braking. to replace those bushings took me forever because they were so corroded up, i spent about 1 1/2 hrs just trying to get them out of the calipers! Then another half hour trying to clean them up before realizing i could actually buy new ones pretty cheap. Installed the new ones with lots and lots of synthetic brake grease. Brakes amazingly now with new bushings and new pads!
So, be sure to grease them up!
Every October I spray the underside of my Festiva with canola oil using one of those garden pesticide sprayers, diluting the oil 25% with solvent to get it to work in the sprayer. I get compliments on having such a "clean", ie rust free in the local jargon, car. I don't spray the brakes though, cover them with plastic bags when spraying.
