Clutch Start Switch
  • Clutch Start Switch
    i thought it was called a safety neutral switch.Anyway i have a 90 festiva manual 5 speed. lately when i push in the clutch it takes it takes a few seconds for it to crank, (a delayed reaction) but it will start. I haven't checked it out yet but was wondering if anyone has had a simular issue with these switches. I don't think I seen anything on this forum about them. Does it need to be adjusted or could the switch be going bad? i tried searching but didn't find anything. Can these switches be found at most auto parts stores, or is this a hard to find part? If the switch does go bad I can still start the car by poping the clutch, right?
    Rich
    You can still pop the clutch and start it. Sounds like the switch is sticking spray it with brake cleaner. Any clutch safety switch I ever saw was 2 prong normally open switch if you put a bent paper clip in the back side of the connector the car will always crank clutch in or clutch out bypass the switch as I said if the problem is gone by a new switch or remember to push in the clutch before cranking.Most of the cars I've owned never had a clutch switch when they were built.
      Correct. It is not good to forget to push the clutch in when parked facing another car in a parking lot. Just post a WTB in the want to buy thread.
        Garage mechanics have a bad habit of parking a car in gear. I never do so most times I went to pick up my car the car would lurch. Don't have that problem with the Festiva.
          I always park mine in gear.
          Jerry
          Team Lightning
          Owner of Team Lightning
          93 L Lightning. BP
            Thanks, I"ll try the brake cleaner.Anyone know if the switch can be bought at most auto parts store?
            Rich
              Rich
              What do you mean by asking if you could still start it by popping the clutch? Do you mean roll start it? If so then yes.
              I would rather my park brake cable didnt freeze so i always just leave it in gear.
                yeah that's what i meant.Thanks.
                  The festivas are easy to roll start by yourself with one foot on the clutch and one foot out the door.
                  With that switch- have you looked at it yet? Is it loose, corroded, burnt? Do you have an auto wrecker nearby?
                    If the parking brake isn't used the clevis pins at the back are more likely to rust and then it can't be used if needed. Happened to me so after replacing the pins I started using the parking brake and not leaving it in gear when parked. One way of keeping things from rusting solid is to use them, ie keep them moving.
                    The switch is on the floor under the clutch pedal lever. Should be easy to spray with penetrant or replace if you can find a new one. Four Green seems to have Festiva/Pride specific parts at reasonable prices but you do have to pay shipping. My sway bar bushings came quickly all the way from Korea by FedEx.
                      Spray it with brake clean.Brake clean will also clean the contacts.Penetrant isn't good for plastic and will not clean the electrical contacts it also will cause more problems as dirt and dust stick to the petroleum base.Carb cleaner is to hot of solvent and will make the plastic soft.Electrcal contact cleaner would actually be best but most expensive and not as many other uses as brake clean.I would use brake clean.
