Size of metric brake line fitting on Festiva?
  • Size of metric brake line fitting on Festiva?
    I cannot source brake line with the correct metric fittings locally, and one fitting was FLUSHED DOWN THE TOILET :evil: (to be expected with my luck)...I was going to reuse the fittings on standard 3/16" line and use a friend's flaring tool. Now I think the easiest thing might be to use the net to hunt down the fittings. So what size are they? color? :?
    4-spd 1989 Festiva - carburated baby!
    FYI: The fittings are 10mmx1.0mm thread with no "lead" (unthreaded area at tip). The brake line is standard 3/16" inverted flare (like domestic cars). NAPA was the only chain that had what I needed, consider them a first stop if you have one in your area. Hopes this saves someone time
