Hi I picked up a yellow cluster for a festy and I couldn't get it to work I noticed it has eight pins on it and my white cluster has seven is there any way to get the yellow cluster to work?
yellow tach cluster help
All clusters made for US cars should just be plug and play. Not sure why yours is not working.Originally posted by wisconstiva View PostHi I picked up a yellow cluster for a festy and I couldn't get it to work I noticed it has eight pins on it and my white cluster has seven is there any way to get the yellow cluster to work?Last edited by TominMO; 11-25-2015, 06:12 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
If the plastic center pin on the cluster is broken off (not uncommon), the plug can be put on wrong. Maybe that's the issue?Originally posted by wisconstiva View PostAlright maybe I didn't line up the plug in right or something.thanks man90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
