List of wheel sizes to fit stock 89
  • List of wheel sizes to fit stock 89
    Hey I'm looking for a list of a the wheels that fit a stock 89 from any other makes and models. Or a link to that list thank you. I'm about to hit up the JYs to find some
    Sent from my XT1585 using Tapatalk
    Go back to the home page and look in the custom suspension, brakes, and wheels forum. It's at the top of the page.
      ^x2
      Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
      Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
      Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
      it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
      Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
      TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
      bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
      '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
      SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
      R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
      R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
      R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
      R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
      R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
        The list is helpful but not entirely accurate it also doesn't note which wheels are hub centric and fit festiva hubs.I ended up with two sets of 13's one set fits the bolt pattern but not the hub but the geo metro wheels fit like they were made for the car.buy em bolt em on they even use the festiva lugs
          We've had this debate many times. Hub-centric doesn't matter! What centers the wheel is simply the lug bolts (or studs/nuts). Once two are on, the wheel is centered. Otherwise the aftermarket wheels (none of which are hub-centric) would cause problems, and they don't.
          For thicker aluminum aftermarket wheels, you do need lug bolts with a longer tapered section, to better grab the wheel. Stock lug bolts are too short in the taper, and the wheel will vibrate at hwy speeds. I've converted my Festy and Aspire to screw-in studs and lug nuts, far more convenient.
            Picked up some geo wheels today at the pick n pull $13 a piece and a protege steering wheels looms awesome
              Great! Do they have good tires?
                They have some decent rubber not the best but its better than the wires I'm running on now.
                  Good enough. Save up for some high-quality, long-wearing tires, like my current all-around faves: General Altimax RT43. They come in a 175/70-13.
                    What do those run a piece. And I wish I had more money to make my car nicer Ive wanted to make it a rally racer since I've got it but just recently found this awesome thread
                      Here you go: General Altimax RT43 175/70-13 from www.tires-easy.com. I've bought plenty of tires from them, with consistent good service/fast delivery. Just get a local shop to mount and balance. The small general auto repair shops are more willing to do this; don't go to the tire places. Figure ~$50 to dismount the old tires, mount/balance the new ones.
                        There is more to hub centric and lug centric than just centering the wheel.With a hub centric wheel impact loads are transferred to the hub rather than the lugs themselves.Some,not all aftermarket wheels are hubcentric. I will remove and replace at least 40 wheels this week at work and 90 percent will be a snug fit on the hub.I leave the engineering of the vehicles to the engineers that designed the vehicles. In my 30 years as working as a tech I have learned many times the engineers usually know what they are doing and may have reasons we are unaware of.
