Engine Transmission Fit?
  • Engine Transmission Fit?
    I'm thinking about getting this for a 92 Automatic Festiva.
    Will it work with my ecm and vaf? Other Issues?
    http://www.ebay.com/itm/Ford-Festiva...-/281709590254
    That trans might be electricity controlled but other than that you should be able to make it work.
    The b3 ecu should run it just fine. It can handle a b6d.
    You may need a 16v disty for it to be clocked right.
    Just looked again it has the disty.
      The aussies got B5's with 4 speed autos in their aspire. My guess is thats what that is, even though it says 91-93.
      91GL BP/F3A with boost
        Thanks guys...
        I tried to ask the seller questions but they are not accepting questions, so with too many unknowns I'm not going to take a chance on this.
          It would be super cool to have that setup in a festy but as you can see they cut the transmission harness. You would need the controller.
