Battery light
  • Battery light
    What would cause my battery light to be on. It has been on for about 4 days now. Battery still seems to be holding a charge so I'm assuming alternator is still working. It came on going to work and hasn't went off yet. I checked fuseable links and battery connections. I haven't had much time to dig any deeper.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    93 L plus 5 speed, custom herculined paint job, custom billet grille
    It's probably the alternator. I drove my car for about six months with the battery light on. When it first started the voltage checked between 12.5 and 12.7 at idle and it started and ran fine. I drove it for about 6 months with no problem and then decided to check it again randomly. It was 12 even at idle and 12.2 at 2000 rpm. I put a new alternator on and it was back up to the 12.5- 12.7 and the light turned off.
      Be careful or you could end up like I did.
        Thanks I hope it's just the alernator. I'll have it tested here in a day or two
          Just letting everybody know my battery light was on because the wire going to my alternator was completely chewed in two.
            "the wire going to my alternator was completely chewed in two" Darned alernator mice! Set a trap or it will happen again.
              There is only one thing that I hate more than alternator mice...
              Fuel pump mice!
                Could have been alternator chupacabras......
