Ok, so I need some input on a snag I'm having.
I'm getting ready to put my lil festiva on the road for winter, with its new lil b6 head, but there's a problem, when i rebuild this motor, the lower half came out of the woods, and I couldn't get new rings so i used the old ones, they all were within tolerance after a good hone, but the number 3 cylinder was pitted a bit because the valves were open on that cylinder, so i honed as much as i could before the ring gap became too much, needless to say, there was still a bit of roughness on the wall after maximum honing.....ANYHOW, the engine runs very well, but during the first few test runs, it was leaking oil from the cam seal, I then realized that i never put a new one in when i rebuilt the head, so I replaced it, BUTTTTTT!, when i went to tap the new one in, it went right into the engine! SO, I pulled the valve cover and using strategically place alen keys, i managed to re-seat the seal into place, and am pretty sure it was not damaged during the procedure, but the car still leaks oil there, not as much, but still. I'm suspecting too high crank case pressure due to the looser rings in the number 3 and this is overloading the PVC system and slightly pressurizing the engine crank case forcing oil out. Sorry this was so long but i wanted everyone to know all the facts to help me find the problem
