WA Transmission in a WB Festiva
  • WA Transmission in a WB Festiva
    Hi all,
    I have an auto 94 WB Festiva with transmission problems and i can get my hands on a WA auto. My question is can this change be made?
    I can see there are a few differences which can be worked around (wiring and a few other relatively minor things) but the 2 things that concern me are
    1. The torque convertor is slightly different in size and connects differently to the flywheel
    2. There is an engine mount bracket which is different.
    The rest of the components look like they can be switched between the 2 to make it work.
    Thank you for your time!
    Cheers
    Is your WB a 1.5 with the 4 speed auto by chance?
    91GL BP/F3A with boost
