Cyl head interchange
  • Cyl head interchange
    Is there a stock B6 head that will replace my B3 head without modification or is the chamber volume or valve clearance different? How about 86-89 sohc 1.6L - B630-10-100F?
    You need an entire engine. That early 1.6 is a direct swap in of the 1.3
