Well I couldn't find anyone who could test the ICM so I purchased a new one. Still no spark! New coil, new ICM... any other suggestions?
91 Festiva cranks over but won't start
Instructors at school stress the point of Visual Inspection. Look at all your electrical connections. You want everything to be (in the everlasting words of Mr. B) "Shiny, bright, clean, and tight". Corrosion and loose connections should be addressed to eliminate variables. If faulty connections are not the problem, check for power. Do you have a DMM? Probe around and make sure you have power to the coil (I believe the coil is low-side driven, but I can't say for sure). Next, I would check to make sure the coil is good, but I think these coils might have an isolated secondary winding. Does anyone have any input on that? Good hunting. Use those trouble shooting skillsA mechanic knows how; A technician knows why.
Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
FB Festiva page: Jared Bennett
Instagram: jaredbear82
I had this happen to me. The little wire that goes to the coil looked to be good but on a very careful inspection it wasn't. It took me forever to find it because the little end looked to be perfect but it wasn't. Problem solved for me after hundreds of trying different things.
It was the little end of the tiny wire where it hooks directly to the coil that looked to be good but on very close inspection it was not. Under the little plastic cover it was frayed where you couldn't see it and was not completing the connection properly..Last edited by Old70; 01-28-2016, 09:06 PM.
Had a similar issue, ended up being corrosion inside of a plug. Towed the car 4 hours to my dad so he could look at it for me and all he did was unplug a few things to make sure I hadn't bent any pins, and when he had me turn it over to check something else, she fired right up. Might be worth it to unplug and check plugs that have to do with that system.Joey Richard Jr.
1991 Ford Festiva L; died but donated all her organs
1988 Ford Festiva LX; EFI swapped in...actually everything swapped in
Quality is Job 1. Together, We Can Save Lives. Ford.
There is a way to test it but i dont know how. A bunch of years back mine quit and wouldn't run. a neighbour came over to give me a hand and did something. I cant remember exactly what but i think he connected 2 wires right at the dist plug and it fired up. So hopefully someone can help you out. I just dont remember what he did.
