Recently got my 90 Festiva all stock and noticed the fan seems to turn on whenever the key is in the ON position, and stays on even while the car is cold. Reading in the Haynes repair manual it sounds like it should be on all the time if the thermostatic switch is grounded. I don't understand if that means it will just be on all the time or will that switch lose ground when the cooling system is still cold after driving in colder temps? More of a curiosity, wondering if the fan on all the time potentially is just making for a colder running car. (Temp gauge heats up just fine after 10 minutes). Thank you for any insight.
