Help 89 festiva Efi won't start
  • Help 89 festiva Efi won't start
    Has spark has fuel and compression and it won't fire
    Make sure your timing is correct.
      Timing is dead on
        Check the cap to see if it is damp inside and check the contacts for corrosion.Make sure the coil wire going into cap is clean and tight.Those are the most common place to start for me.When cap is off take a look at the dist. rotor. If that doesn't do it check spark plugs and then wires.
          Checked all that have good spark to the plugs have fuel through the injectors timing is on still won't spark or fire
            Start or fire I mean
              Check compression?
                Yes has good compression
                  You could check engine management fusible link bank under the hood.Bank of 3 on drivers side shock tower.Engine management is the one closest to passengers side.It doesn't sound like it is that but it is easy to check with a test light to see if you have power there.
                    Maybe your ignition switch?
                      Ignition control module
                        Take out the spark plugs and put one teaspoon only of gas in each cylinder and the put the spark plugs back in and try it again.. you can use an eye dropper or something a tiny amount in each cylinder
