I just pulled the cluster out of my 89L.
It was updated by the PO at some point to a tach unit (oranage).
The reason I pulled it was it had a seriously screwed speedo (bouncy @ low speed & pegged @ hi) and no gas gauge operation (always empty).
What I found was a pair of wires jumperd to screws on the circuit board that routed thru the firewall to the coil. ??
I pulled the R. seat & tested my sender ...good
I cleaned the connector's reassembled then I tested continuity of the yellow wire from the sender to the connector under the dash...good
So Im replacing the cable which I think will solve my bouncy speedo, but how do I proceed with the gas gauge?
Does it also have to be externally wired (two wires from circuit board to coil)?
So what is the wire loom difference between the L & LX?
The wire loom for the body including the tank sending wire(s) are the same, until they connect to the loom section under the dash.
Against conventional wisdom apparently the L & LX DO have a different loom section running behind the dash connecting things like HVAC ctrls, cluster, R window ctrls, AC, pwr mirrors ect.
Perhaps not all, but mine.
The 1st indication that something was amiss was when I went to plug in the pwr mirrors only to find there were no connectors.
Now Im faced with swapping a LX dash loom (which looks to be a MAJOR PITA) or independently wiring all the options not installed on my car.
Has anyone BTDT?
I just want important indicators like my gas gauge & speedo to WORK!
Has anyone BTDT?
