Hi all. I hope that someone might help. Recently my car reved high when the car first starts. Once you get down the road a bit it seems to sort itself out. This seems to happen when it is cold. We were told to replace the TPS so we did. Worked for about a day then back the reving high at start up. If you mess around with it and get the idle sorted, it then drives like a slug. Put your foot down and there is no get up and go. You adjust that and it goes back to idling high. Took it to a mechanic and they
cleaned off the throttle control valve and adjust the throttle adjustment screw
Thought they had fixed it but sadly no.
So, it happens when it's cold. If you let the car cool down and start it again, it happens again.
Does anyone have any ideas on what might be wrong? Any help would be appreciated. TIA.
