Both front indicator/ blinker/ turn signal.....not working. Help please
  • Both front indicator/ blinker/ turn signal.....not working. Help please
    Hi I'm the new boy.
    My 1996 trio's front orange flashers have stopped working. All the others still work on turn and hazard switches.
    I had both front flashes 'out' while I did some minor body repairs.
    Upon reinstallation, no workum.
    Is there an inline fuse/ fuse just for these two lights?
    I don't have an owners manual so can check there.
    Thanks in advance.
    DIMMO
    If your car is like a festiva, there are two round electrical connectors under / behind the drivers side head light. The big connector can hold water and cause strange problems.
      Assuming the bulbs are good and making good connections in the sockets, then you either lost B+ to one terminal or ground continuity to the other terminal. Check the terminals and see which way you need to troubleshoot.
