how hard is it to replace clutch in a 91 festiva is their any kind of directions or manual around dont quite have the money to pay someone to do it for me
replacement clutch
1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
1991 GL - B6d, g-series trans, aspire brakes, Advanced Suspension coilovers, Miata 7 spoke rims, '98 Prelude seats, more to come!
2005 Focus ZX4 SES - purchased from original owner, my grandmother. Currently my wife's daily. 210k
You can follow me on instagram @twfodor
Clutch is easy if you can remove the front 2 cross member bolts (that area has a habit of rotting). Call me and I can walk you through it: 717-725-7798Trees aren't kind to me...
Originally posted by vinelandidiot13 View Postwell ive ordered a clutch kit and a new flywheel i have never done anything like this completely new to this so hopefully its something i can do on my ownmost important is to use a manual. Print off the link above or if you prefer go buy a haynes manual for $20. I used the haynes. You basically cant screw it up if you follow their step by step instructions with all their pictures
Originally posted by vinelandidiot13 View PostOk cool yes I have the Haynes manual
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
Dont forget new transmission fluid. You dont have to, but its a good time to change the transmission output shaft seals (cv shaft seals on the trans side). They are cheap and its a huge pain to change them later if they are all you have to do. Its easy while your doing the clutch.
Have a bunch o brake cleaner or degreaser to clean up everything inside before installing the new clutch. Take pictures as you go in case you forget which way something went back togeather. Organize all your bolts and parts while removing. And take your time, dont be too rushed. Should only be a one day job though.
http://m.ebay.com/itm/271063606900?_mwBanner=1 that's what I got and flywheel from rockauto
Originally posted by vinelandidiot13 View Posthttp://m.ebay.com/itm/271063606900?_mwBanner=1 that's what I got and flywheel from rockauto
I'm still available as a resource...Trees aren't kind to me...
