Hello all!
Had a bit of a setback this evening on the project car. Task on hand was to bleed the brakes. I bench bled the master then went to the right rear wheel. I used my bleed tool at first and then tried the old fashioned way with my wife pushing the pedal and me at the wheel cylinder. Couldn't get any fluid to show using either method. Tried the other corners with no success. Thought it might be the master so I switched it out for the relatively new one I'd pulled from our old red car. Bench bled that with no change at the wheels. There are no leaks showing anywhere.
Am I missing something? Is it possible the proportioning valve needs replacing?
Thanks
Thanks
