Howdy. It's been a long time since I posted. I'm still driving my '88 carby Festiva.
I have a problem with the bearings going out on my alternators. I've replaced it 4 times under warranty from O'Reilly. Every time the bearing goes out. Someone suggested I may have a short going to ground through the bearings.
I know I have a short somewhere. I installed a battery disconnect switch years ago. If i don't shut the switch off, the battery will drain within a couple of days. Now I'm thinking the short, and the alternator bearing failure are related.
The two prong connector that goes in the back of the alternator broke. I have two insulated quick disconnects in it's place.
Any suggestions on what to do?
