Another owner re-wired some ignition wires at the steering column. They burned up 'in-flight'. I've replaced
the steering column with a good one with better wires and harnesses and clips, etc. I have it all together but
one wire goes nowhere.
On the opposite side of where you put your key in is a plastic wire harness that is held in by one phillips head screw.
I need to know where the top right terminal wire (red and black) goes. It's the wire coming from where I'm pointing
my needle nose pliers at in the pic below:
