ok she a 91 1.3L carb festiva, if i go out and let it warm up for a few minutes it runs fine BUT if i go out get it running and start to drive when the motor isnt fully warmed up its gets realy bad flat spots
i know being carbed it has to warm up but if i just drive it i can go on an hour long trip it runs exactly the same after an hour of running as it does at the start , motor is red hot and still flat spots.
it only goes good when the motor is totaly cold then allowed to warm up on its own
i run 98 octane fuel which is the highest octane fuel sold at the pumps here in aus so its not cheap fuel and i doubt its a bad batch cause its been doin it for a while and i've been getting fuel from diffrent stations
