95 Aspire Shifting problem
  • 95 Aspire Shifting problem
    I have a 95 aspire, which might have a blown tranny, would a festiva 5 speed tranny fit into an aspire using stock mounts? The car is stuck in Reverse, clutch cable is in tact. and the shifter just swings loose. is that a shift linkage or not? or is it the tranny? thanks,
    Aaron
    missin my 88 LX 4speed
    95 aspire black soon to become less stock :twisted:
    either the stabilizer bushing is destroyed on the trans , next to the shifter rod
    or
    the shift gate assembly is broken in the trans itself
      how hard is it to repair the in transmission part? or is easier/cheaper to replace it? and will a festiva 5speed bolt right in with stock aspire mounts?
      thanks
      Aaron
        my gate was broken in 1st gear, i just swapped out the tranny myself for a pick-a-pary one for 75 bucks
          Re: 95 Aspire Shifting problem
          Aaron
          Yes , it is the same tranny .
          HD2500 Duramax Chevy
          Z28 LS1 power 500 +
            thanks man, that helps a ton!! now I just gotta get it from Dayton OH to NY...
