Hey, i searched a bunch on the forum but the question seems to be only answered for people looking for more power or with larger motors. I found a bit on google but for other cars and im not sure how well it applies to festivas specifically. My question is what diameter exhaust is best for a stock festiva 1.3L with no plans to make more power? Mine is kinda bashed up and rotted out. I have 2 parts cars so i took the exhausts off both. The one is the standard 1.5in OD but no muffler and the flange is cut off back there. Couple pinholes throughout the pipe and the resonater would have to be replaced but the pipe is not squishable by hand. The other one is out of a carbed festiva so its got the cat with the heat pipe. The outside diameter is 2.1in. Resonater seems in ok shape and it has a flange for the muffler. I have a good muffler with a flange but no brackets, i have to weld them on. So anyway, the 2 inch exhaust is obviously (to me) less work and cheaper to make work- and thats the goal, im not lookin to spend money on it or else i would buy a whole new exhaust. However i do not want to loose any power. *My concern is does the 2.1inch slow the velocity of the exhaust down enough that you loose power on the n/a 1.3L? Or will there be no noticable power difference? The muffler is the stock 1.5in.*
Thanks
Thanks
