I bought a 1989 festiva LX. It has the original 1.3L fuel injected motor with an automatic transmission. It runs great, but after I bought it I saw that it had a brown liquid in the radiator overflow. I immediately flushed the system and topped it off with new 50/50 antifreeze and water. After about a day of driving the water started to turn brown again. I figured that I must have a blown head gasket, so I checked the compression on all four cylinders. All cylinders had equal compression and it was within the specifications in my Haynes manual. This ruled out the head gasket. I may have a cracked block. Is there anything else that can cause antifreeze coolant to turn brown?
Brown Antifreeze
Probably just rust. I had it in one of my cars. I just used a very diluted mix for a few weeks and drained it a few times till it came out clean then went with a 50/50 mix. Also run the hose thru it for a while with the drain open.
was fuel injection an option in '89? i have (and crashed) an '89 with a 4-speed manual and it is carbureted.5 Festys and counting!!
1993 GL auto 126,000mi
1991 red 5-speed B6T G25 swap in progress 255,000mi
1990 white 5-speed/Aspire swap daily driver 273,000 mi.
1989 silver 4-speed parts car
1989 white auto El Festivo
1992 Chevy Silverado K1500 soon to have 383 stroker
1999 Mercury Sable
1992 Pontiac Bonneville SSEi Supercharged For Sale
There were a few automatics in 89 had FI , manual had a carb , in 90 all were FI.------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
