The AC is out on Nellie until I get the system flushed out and a remanufactured compressor installed.
Trixie's ac works but the compressor does not remain running long enough during the hot weather.
I hooked up the manifold gauges this afternoon and the readings are go to Low 30 and hight 225 but
the compressor doesn't run long enough to bring the vent temperature lower that 60 degrees.
This is an 89 automatic efi car with factory installed AC converted to R134a. Before I converted
the system (replacing the compressor, receiver dryer and expansion valve) it cycled ok with the Freon.
I'm sure this is not a refrigerant charge or bad compressor issue.
Can anyone give me some tips on how I can get the ac clutch to remain engaged longer?
